Mojombo
Sep 11, 2012Aspirant
ReadyNas 1000s Documentation
Does anyone have a URL to download a manual for a ReadyNas 1000s User Guide and the Installation Guide? Thanks!!! :D Mojombo
Mojombo
Sep 12, 2012Aspirant
Regrettably I just ran a firmware update check and when it came back that it needed an update I just ran it without noting the version :-(
I rolled it back to 4.1.7 which just fit on the original flash card. I've seen postings that this fixes the original issue of the flash corruption. I'll post later after I get this working what the final resolution of this mess is.
My problem with the drive tray is its stuck and I know that with the desktops when the release button is stuck (common problem) you can inset a pin into on of the vent slots and slip the plastic latch. Just not certain how to do it on the rack version. I just pulled it out of the rack and I'm about to take off the cover.
More later...
More later...
- May 12, 2025Retired_Member
