dkoerner
Oct 17, 2013Aspirant
ReadyNas 102 firmware upgrade failure
Hi, I got myself a ReadyNAS 102 including two 3TB WD harddrives (WD30EFRX). After initial setup it asked me to upgrade the firmware to 6.1.3. After starting the firmware upgrade the system did not re...
Badyoda
Oct 18, 2013Aspirant
Precisely that happened to my 102 as well. I posted about it here too.
Yesterday I installed 6.1.2 again and now it works just fine!
Cut the power ( unplugg it) and restart it again, this should work, then download 6.1.2 to your computer and manually install it from NAS UI.
I hope this helps.
I hope this helps.
