dkoerner
Oct 17, 2013Aspirant
ReadyNas 102 firmware upgrade failure
Hi, I got myself a ReadyNAS 102 including two 3TB WD harddrives (WD30EFRX). After initial setup it asked me to upgrade the firmware to 6.1.3. After starting the firmware upgrade the system did not re...
mdgm-ntgr
Oct 19, 2013NETGEAR Employee Retired
The telnet login is for support's use to investigate issues such as yours.
Things I would have tried would have been things like wiping the disks. updating the firmware manually etc. Though I guess support probably tried those and detected an issue e.g. bad memory.
