dkoerner
Oct 17, 2013Aspirant
ReadyNas 102 firmware upgrade failure
Hi, I got myself a ReadyNAS 102 including two 3TB WD harddrives (WD30EFRX). After initial setup it asked me to upgrade the firmware to 6.1.3. After starting the firmware upgrade the system did not re...
dkoerner
Oct 24, 2013Aspirant
Hi,
yes, firmware update to 6.1.3 worked fine now. So for what I can see, it appears to me that both hard drives are broken.
If I put them in additionally to the working 2,5" the NAS does not show them in the web ui
Is that a reasonable assumption?
Just ironic that two new certified harddrives are broken while a 6 year old harddrive works fine.
