dkoerner
Oct 17, 2013Aspirant
ReadyNas 102 firmware upgrade failure
Hi, I got myself a ReadyNAS 102 including two 3TB WD harddrives (WD30EFRX). After initial setup it asked me to upgrade the firmware to 6.1.3. After starting the firmware upgrade the system did not re...
Oct 25, 2013Guru - Experienced User
Does your enclosure support GPT drives? What were the symptoms of "did not work"? For instance, did Western Digital's Lifeguard program not see them?
Also, did you try the disks one at a time in the RN102? (powering down before insertion).
