dkoerner
Oct 17, 2013Aspirant
ReadyNas 102 firmware upgrade failure
Hi, I got myself a ReadyNAS 102 including two 3TB WD harddrives (WD30EFRX). After initial setup it asked me to upgrade the firmware to 6.1.3. After starting the firmware upgrade the system did not re...
doctoru
Dec 06, 2013Aspirant
Hi,
I had the same problem. Netgear RN10200 + 2x WD RED 3TB, connected via network yellow cable directly to my PC.
Power Led was always blinking and I had no Raidar detection. So I was unable to access my new RAID system.
I've made a factory restore with one disk inserted. you should get leds blinking for about 10-15 min. After tht DISK 1 ld wil be solid and Power Led maybe blinking.
I'v put PC's IP address on automatic, not static IP!... and I accessed the RN102 using http://nas-xx-xx-xx where xx-xx-xx are the last digits of the NAS MAC address.
you'll get the Admin login and after you get setup the NAS. Make sure you have DHCP enabled and connect it to the router to be able to make OS update if you need to.
Enjoy! Netgear has also a very good Customer Support. I solved it trough them.
Good Luck
Good Luck
