Alexpetrovich
Apr 07, 2018Aspirant
ReadyNAS 102 Lost data after firmware update
Hello, everybody! I updated firmaware of NAS 102 from 3.xx to 6.9.3 and lost most of data on it How to recover it with file structure? Thank you for help!!!
Apr 07, 2018Guru - Experienced User
Ok. You are supposed to go from 6.2.5 (or 6.3.5) to 6.5.2, and then to 6.9.3. But I haven't seen posts here from folks who lost some of their data when they ignored those instructions.
You could try powering down, and removing one disk. Then connect it to a Windows PC and see if ReclaiMe software can find the missing files.
viperhansa
Apr 08, 2018Virtuoso
Could it be the that its 6.9.3 that creates this kind of issues??
Read forum and there is several reporting same type of issues, Decativated volumes and such.
// Hans
- StephenBApr 09, 2018Guru - Experienced User
Do you have a deactivated volume? My understanding of your first post was that you lost some data, but not all data. Can you clarify what you did (and didn't) lose?
- AlexpetrovichApr 12, 2018Aspirant
Sorry for long-time answer, I remember feature
First part of data was added from windows PC
After it all data was added from MAC using SMB
Second part ( from Mac ) lost after update
- mdgm-ntgrApr 12, 2018NETGEAR Employee Retired
Can you send your logs (see the Sending Logs link in my sig)?
