simani
May 22, 2015Aspirant
Readynas 102 not at my network internet connexion speed
Hello ! I have a small network performance issue with my readynas : * Although my internet connexion speed is 400Mb/s (France, Numericable), my downloads can't seem to go past 10-11 MBytes/sec ...
mdgm-ntgr
May 22, 2015NETGEAR Employee Retired
Why do you need to run two torrent apps? On the 100 series you should try to avoid running an excessive number of services. Furthermore the torrent apps may be using the Internet.
If you disable the anti-virus service does that make any difference?
