barryd
Feb 23, 2016Aspirant
Readynas 102 not backing up and freezing after upgrade to 6.4.2
My client has a Readynas 102 2x3tb system It is backed up by 2 x WD 3TB disks which are rotated and plugged into the front of the Nas. It has always been a bit problematic in that the WD driv...
- May 20, 2016
O.K. I think this discussion has run its course.
Now that this is fixed in 6.5.0 if you have any issues on that you should open a new thread.
I'm closing this thread.
mdgm-ntgr
Feb 23, 2016NETGEAR Employee Retired
Which filesystem is on the USB disks?
Can you send in your logs (see the Sending Logs link in my sig)?
barryd
Feb 24, 2016Aspirant
mdgm wrote:Which filesystem is on the USB disks?
Thanks mdgm. Ive forwarded the logs just now.
Unfortunately the back up drives have now been reformatted on the Macs and are being used on them as external drives. I think they are dragging data manually back off the NAS as a temporary measure.
Before that they were formatted on a Windows 7 PC using the defualt which I think would be NTFS.
I dont think there was a succesful backup since late January. Ever since the upgrade to 6.4.2 and it started freezing the NAS they have been disconnected, the backup schedule stopped and as said they are now plugged into one of the Macs.
I can format one of them if you wish for testing in any format you like. Let me know if you want me to enable remote access to the NAS.
Regards
Barry
- mdgm-ntgrFeb 24, 2016NETGEAR Employee Retired
When they tested the USB disks on a PC, did they use the disk vendor's tool for checking disk health or something else?
- barrydFeb 25, 2016Aspirant
mdgm wrote:When they tested the USB disks on a PC, did they use the disk vendor's tool for checking disk health or something else?
I dont think they did any of that. All they will have done is formatted the disks. This has worked in the past when they have been set to read only. Same on both disks. In the past formatting them corrected the problem and the backup would work but this no longer happens and the backup fails with the nas freezing.
- StephenBFeb 25, 2016Guru - Experienced User
I think the next step is to test them - especially if they used the quick format. Reformatting often is just concealing the real problem.
- Jan 17, 2024Retired_Member
