barryd
Feb 23, 2016Aspirant
Readynas 102 not backing up and freezing after upgrade to 6.4.2
My client has a Readynas 102 2x3tb system It is backed up by 2 x WD 3TB disks which are rotated and plugged into the front of the Nas. It has always been a bit problematic in that the WD driv...
- May 20, 2016
O.K. I think this discussion has run its course.
Now that this is fixed in 6.5.0 if you have any issues on that you should open a new thread.
I'm closing this thread.
paulhulsephoto
Feb 25, 2016Aspirant
Hi im not sure if this is one in the same problem but i am at a loss...
I too have the same ready nas 102 but with 2 1gb drives it worked fine untill apple upgraded os to El Capitan then all of a sudden, i can access the ready nas and see all of my folders/shares but then as soon as i try to access a folder it crashes finder, at some point there was an update and all started working again but since a recent apple security update it has gone back to crashing finder maybe a coincidance. i can access the drive via Raidar and time machine finds and backs up fine.
any help on if i can fix this would be great
Thanks
- Jan 17, 2024Retired_Member
