barryd
Feb 23, 2016Aspirant
Readynas 102 not backing up and freezing after upgrade to 6.4.2
My client has a Readynas 102 2x3tb system It is backed up by 2 x WD 3TB disks which are rotated and plugged into the front of the Nas. It has always been a bit problematic in that the WD driv...
- May 21, 2016
O.K. I think this discussion has run its course.
Now that this is fixed in 6.5.0 if you have any issues on that you should open a new thread.
I'm closing this thread.
barryd
Mar 10, 2016Aspirant
Thanks John that would be useful as I do need to get it resolved, backing up across the network is not really working very well.
I dont understand why Netgear keep saying the 102 is a basic model. The one I am working on serves just two Macs, if its not designed to cope with just two computers what is it designed for?
YorkBoy
Mar 10, 2016Luminary
Hi
To be fair 'base model' is my terminology but looking at the catalogues it is the cheapest device and it has already been pointed out to me on here that I shouldn't be using this for business and a 312 was suggested.
Quite frankly I wasn't best pleased by this attitude because to me this was yet another grasping at straws approach to divert me away from the true nature of the defect.
My 102 is a home device on which I have some work data. As I keep saying, data is data, its 1's and 0's and even the moving around and accessing a few files by perhaps two or three computers in a work environment is surely not as 'stressful' for a NAS as say two people accessing media files with films in a true home environment? In any event the daytime use does not alter the fact that overnight unattended backups do not work.
I have already emailed my contact about your issues.
Regards
John
- barrydMar 10, 2016Aspirant
Thanks again John, look forward to hearing from them.
The 102 works fine for what its been put in place to do. There was an issue with the Macs accessing the drive but that turned out to be an Apple issue. In terms of performance for accessing the data its fine. The PC's also back up their Outlook etc to it. Its just the firmware upgrade 6.4.2 that screwed up the backup that needs sorting. Fix that netgear and we will all be happy bunnies.
- YorkBoyMar 10, 2016Luminary
Reply come in
"Hi John, Thank you for your messages. I will test the front USB port with the information you provided, and I will also run a few more tests on the units. Unfortunately, I cannot add another client to the case, but you can advise him to open a separate case for the issue he is seeing. Even if the symptoms are similar, it is always possible that the source of the issue may differ and we need to investigate each case individually. I will let you know as soon as I have more information, thank you again for your patience on this matter. "
It seems you need to raise your own support ticket. Perhaps it might be a good idea to say that this is already being partially investigated and my support ticket is # 26140511
Ok?
John
YorkBoy wrote:Reply come in
Ok?
John
Thanks
How do you go about raising a support ticket?
Hi
Look at the top of this page right hand side, Support.
Follow that through.
You'll need information like model and possibly serial no. as well.
Take the support for home route as thats what a 102 comes under I think. Expect hassle.
Remember to point out that all was well until 6.4.0 or 1 or 2 and point out my support ticket no. and that you have been onto the forum and see numerous others all with 6.4.0 issues and especially 102s that won't backup.
Ok?
John
- slotmachineMar 10, 2016Tutor
1. I ran a few tests with 2 RN102 from our lab: one on 6.2.5, the another on 6.4.2
2. I copied the exact same data to both of them : 15GB (total) - a mix of big and small files
3. I ran backup jobs on both NASes (full backup of the data volume) using the same USB 3.0 stick, NTFS formated and plugged to the rear ports
4. There was a noticeable difference between the 2 backup jobs: it took over 2 hours on 6.4.2 and around 40 minutes for the one on 6.2.5
This is the same behaviour I see. Transfer speeds of around 1.5MB/s while the GUI becomes unresponsive and the unit requires a hard reset. I have explained in my support ticket (#26576559) that at that rate it would take a month to back up the 4TB drive in my 102.
Hi
If you have not already done so, I suggest you ask them to refer to my support ticket no. #26140511
Finally Netgear appear to be taking this matter seriously and the more people that raise it through the proper channels the more chance we have of getting something done.
John
Ok thanks guys. I have now submitted a similar support ticket. #26587405
So it is pretty clear that the upgrade has created this issue. Ideally I need the front usb backup sorting and not just the backup speeds on the rear port. The front usb crashes the entire unit and the rear ones are unusable due to it taking too long and rendering the NAS useless.
Hi Barry
if you look at my recent comments to another user they too have had the same issues.
i think we are finally going to get some action but it both annoys and saddens me that it's taken five months of hard slog and bad feeling to get here. This really should not be necessary.
My Netgear support engineer says he is testing the front socket.
It almost seems as if the rear sockets are running usb 1. My front socket does work but only does a tiny backup, stalls and then hangs the NAS.
i breathe a sigh of relief every morning when I see a successful backup.
john
- StephenBMar 11, 2016Guru - Experienced User
I just tried this on my RN102 - which is running 6.5.0-T322 beta. The external drive is a Crucial SSD in a Patriot Gauntlet USB enclosure, formatted NTFS. The enclosure was connected to the USB back top port of the RN102.
I ran two local->local backups:
Music: 58.2 GB - 15,414 Files, 974 Folders
42:15 run time, transfer speed ~23,5 MB/sec
Photos: 21.6 GB - 19,417 Files, 483 Folders
16:48 run time, transfer speed ~22 MB/sec
- barrydMar 11, 2016Aspirant
StephenB wrote:
slotmachine wrote:1. I ran a few tests with 2 RN102 from our lab: one on 6.2.5, the another on 6.4.2
Thanks
Did you try the front port?
Those speeds sound more like it so is this a fix? (Assuming it works of the front port)
- slotmachineMar 11, 2016Tutor
That sounds promising. Do you have any idea how long it will be until 6.5.0 Beta is available?
- YorkBoyMar 11, 2016Luminary
Evening.
Reading all this is very interesting.
Please though will someone (Netgear) just test the front socket for goodness sake and put us out of our misery.
Does it hang your 102?
Thanks
John
There was no lockup, but the backup speed dropped and the web ui seemed less responsive.
Running the same Music backup to the same drive connected to the USB front port resulted in
2:09:16 run time, transfer speed ~7.7 MB/sec
A big dropoff from 23.5 MB/sec.
- YorkBoyMar 12, 2016Luminary
Good morning.
Thank you for this. Interesting that it didn't hang your 102. My 102 has frozen on using the front socket everytime I have tried to use it since 6.4.0.However interesting it slowed down considerably.
When you reported speeds yesterday on using the rear sockets, exactly what were you backing up to and what speed were those devices?
Ditto the front socket?
Thanks
John
- StephenBMar 12, 2016Guru - Experienced User
For both front and rear sockets, I used a Crucial SSD drive in a Patriot Gauntlet USB 3 enclosure. I measured write speeds on Windows 7 of ~175 MB/sec with NASTester.
My USB 3 testing options are limited - the Gauntlet is 2.5", and the only 2.5" drive I have available to test with is the Crucial SSD.
Stephen.
Thank you.
I was thinking about my rear USB 3 sockets backing up to WD USB 3 hard drives.
I was getting around 140GB backed up in 1hr 5 mins on the last time under 6.2.5.
I'm now getting 145GB backed up in 4hrs 24mins under 6.4.2.
So my original setup, 140GB in 65 mins works out at around 35MB/sec, still much faster than your latest results using the beta firmware.
John
Apologies, I should have said.
NTFS.
2.5" drives WD 1TB USB 3.
- barrydMar 13, 2016Aspirant
Just to chip in my drives are 3tb WD formatted to NTFS as well.
Backing up about 250GB, used to take 4 hours on 6.2.5 and has now never backed up completely overnight on 6.4.2 as it ground to a halt and had to be stopped after 15 hours as it reduced the NAS to being unusable.
Currently now backing up across the network to the same drive connected to a PC and taking around 4 hours to back up.
- YorkBoyMar 13, 2016Luminary
Hi Barryd
When I back up using the front socket even though it freezes the NAS it does actually appear to start ok and does backup a few folders amounting to perhaps 1GB before feezing the NAS.
This event seems to be exactly the same scenario as your issue on the rear sockets so can you confirm if any backups are actually taking place?
The fact that my rear socket backups do work, albeit taking four times as long makes me wonder if that's simply because I only back up 145GB, that being the entire contents of my NAS. It would be interesting to see what would happen if I had substantially more data being backed up.
What response (if any) have you had from your support request?
I am going to repeat my comments that for a moderator here to confirm he sees the same failures as us and for a Netgear engineer to report the same on a single test of a backup on a 102 makes me seriously question the quality of the firmware testing regime. After all people who have a NAS are the kind of people who take the safety of their data seriously and those people are going to perform back ups. It stuns me that it seems backing up on a 102 was never checked using the 6.4.0 series of firmware.
John
Hi Barry
You know I was thinking just no, I bought this 102 to replace my earlier V1 Readynas and I really wonder why I bothered.
The old V1 was never an issue, ran perfectly for years backing up every night.
The 102 has been hassle since I bought it and actually the very first issue I had was with using the USB sockets. On inserting a USB stick into the front socket all went well until I ejected the stick, then although the stick was correctly ejected and removed it still appeared in shares. In discussions with Netgear it was called a ghost share and I waited perhaps months for a fix that actually worked.
I have had other issues with the 102 causing me to lose data and I had to perform a complete reinstall.
Seriously thinking today whether to get the old V1 up and running again.
John
The only response I have had from my support request was asking for the serial number which I provided when I originally posted it and if I was the registered user of the product.
I think this NAS does start to back up through the front usb but I am not sure at what stage it locks up.
I think through the back ports overnight it got about as far as 100gb or so but I Cannot be certain before I had to shut it down.
I too used to be very happy with Readynas and I recommended them and indeed my company resells them. At the moment I would be reluctant to supply any more units and I am advising clients not to upgrade their firmware if they have a working system at the moment but as was the case with this particular NAS the end user just went ahead and upgraded it which to be fair they should be able to do in confidence that its been properly tested.
I have always supplied and recommended Netgear products and not just NAS equipment as they are generally very good and I would like to continue doing so but this episode with the NAS and the time its taking to resolve has done nothing to boost my confidence to be fair.
If Netgear want to supply me with some kit I would be quiet happy to test them! :D
Hi
Considering 6.4.0 was released in October then it sure is taking a long time to resolve the issues.
I totally fail to understand why it is that there isn't a simple authorised route back to 6.2.5. Now I know it's supposed to be possible but before I do it I would like to know if I'm going to get myself into any issues. Let's be honest what help am I likely to get if I downgrade and brick my NAS?
However given that it seems so many people have issues it's about time Netgear came clean and gave us a route to do this so we can all get our systems working again.
Once it's running properly I can't see I'm going to ever update the firmware again and please don't anyone tell me that I should because of all the new features I would get because one feature I definitely don't want is a NAS that fails to back up!
I just wonder if rather than keep the firmware and interface simple they are trying to provide too many features most of which the average person doesn't want or need and in the process have ruined some pretty basic and necessary facilities. I don't suppose we'll ever know.
John
- StephenBMar 14, 2016Guru - Experienced User
Just wanted to add that I reformatted the SSD to ext4, and tested both USB ports again. The results are here: https://community.netgear.com/t5/ReadyNAS-Beta-Release/6-5-0-T322-RN100-series-front-port-USB-performance-is-sluggish/td-p/1061142
- Jan 17, 2024Retired_Member
