barryd
Feb 23, 2016Aspirant
Readynas 102 not backing up and freezing after upgrade to 6.4.2
My client has a Readynas 102 2x3tb system It is backed up by 2 x WD 3TB disks which are rotated and plugged into the front of the Nas. It has always been a bit problematic in that the WD driv...
- May 20, 2016
O.K. I think this discussion has run its course.
Now that this is fixed in 6.5.0 if you have any issues on that you should open a new thread.
I'm closing this thread.
slotmachine
Mar 10, 2016Tutor
1. I ran a few tests with 2 RN102 from our lab: one on 6.2.5, the another on 6.4.2
2. I copied the exact same data to both of them : 15GB (total) - a mix of big and small files
3. I ran backup jobs on both NASes (full backup of the data volume) using the same USB 3.0 stick, NTFS formated and plugged to the rear ports
4. There was a noticeable difference between the 2 backup jobs: it took over 2 hours on 6.4.2 and around 40 minutes for the one on 6.2.5
This is the same behaviour I see. Transfer speeds of around 1.5MB/s while the GUI becomes unresponsive and the unit requires a hard reset. I have explained in my support ticket (#26576559) that at that rate it would take a month to back up the 4TB drive in my 102.
Mar 11, 2016Guru - Experienced User
I just tried this on my RN102 - which is running 6.5.0-T322 beta. The external drive is a Crucial SSD in a Patriot Gauntlet USB enclosure, formatted NTFS. The enclosure was connected to the USB back top port of the RN102.
I ran two local->local backups:
Music: 58.2 GB - 15,414 Files, 974 Folders
42:15 run time, transfer speed ~23,5 MB/sec
Photos: 21.6 GB - 19,417 Files, 483 Folders
16:48 run time, transfer speed ~22 MB/sec
- barrydMar 11, 2016Aspirant
StephenB wrote:
slotmachine wrote:1. I ran a few tests with 2 RN102 from our lab: one on 6.2.5, the another on 6.4.2
Thanks
Did you try the front port?
Those speeds sound more like it so is this a fix? (Assuming it works of the front port)
- slotmachineMar 11, 2016Tutor
That sounds promising. Do you have any idea how long it will be until 6.5.0 Beta is available?
- YorkBoyMar 11, 2016Luminary
Evening.
Reading all this is very interesting.
Please though will someone (Netgear) just test the front socket for goodness sake and put us out of our misery.
Does it hang your 102?
Thanks
John
- StephenBMar 11, 2016Guru - Experienced User
There was no lockup, but the backup speed dropped and the web ui seemed less responsive.
Running the same Music backup to the same drive connected to the USB front port resulted in
2:09:16 run time, transfer speed ~7.7 MB/sec
A big dropoff from 23.5 MB/sec.
Good morning.
Thank you for this. Interesting that it didn't hang your 102. My 102 has frozen on using the front socket everytime I have tried to use it since 6.4.0.However interesting it slowed down considerably.
When you reported speeds yesterday on using the rear sockets, exactly what were you backing up to and what speed were those devices?
Ditto the front socket?
Thanks
John
- StephenBMar 12, 2016Guru - Experienced User
For both front and rear sockets, I used a Crucial SSD drive in a Patriot Gauntlet USB 3 enclosure. I measured write speeds on Windows 7 of ~175 MB/sec with NASTester.
My USB 3 testing options are limited - the Gauntlet is 2.5", and the only 2.5" drive I have available to test with is the Crucial SSD.
- YorkBoyMar 12, 2016Luminary
Stephen.
Thank you.
I was thinking about my rear USB 3 sockets backing up to WD USB 3 hard drives.
I was getting around 140GB backed up in 1hr 5 mins on the last time under 6.2.5.
I'm now getting 145GB backed up in 4hrs 24mins under 6.4.2.
So my original setup, 140GB in 65 mins works out at around 35MB/sec, still much faster than your latest results using the beta firmware.
John
Apologies, I should have said.
NTFS.
2.5" drives WD 1TB USB 3.
- barrydMar 13, 2016Aspirant
Just to chip in my drives are 3tb WD formatted to NTFS as well.
Backing up about 250GB, used to take 4 hours on 6.2.5 and has now never backed up completely overnight on 6.4.2 as it ground to a halt and had to be stopped after 15 hours as it reduced the NAS to being unusable.
Currently now backing up across the network to the same drive connected to a PC and taking around 4 hours to back up.
- YorkBoyMar 13, 2016Luminary
Hi Barryd
When I back up using the front socket even though it freezes the NAS it does actually appear to start ok and does backup a few folders amounting to perhaps 1GB before feezing the NAS.
This event seems to be exactly the same scenario as your issue on the rear sockets so can you confirm if any backups are actually taking place?
The fact that my rear socket backups do work, albeit taking four times as long makes me wonder if that's simply because I only back up 145GB, that being the entire contents of my NAS. It would be interesting to see what would happen if I had substantially more data being backed up.
What response (if any) have you had from your support request?
I am going to repeat my comments that for a moderator here to confirm he sees the same failures as us and for a Netgear engineer to report the same on a single test of a backup on a 102 makes me seriously question the quality of the firmware testing regime. After all people who have a NAS are the kind of people who take the safety of their data seriously and those people are going to perform back ups. It stuns me that it seems backing up on a 102 was never checked using the 6.4.0 series of firmware.
John
Hi Barry
You know I was thinking just no, I bought this 102 to replace my earlier V1 Readynas and I really wonder why I bothered.
The old V1 was never an issue, ran perfectly for years backing up every night.
The 102 has been hassle since I bought it and actually the very first issue I had was with using the USB sockets. On inserting a USB stick into the front socket all went well until I ejected the stick, then although the stick was correctly ejected and removed it still appeared in shares. In discussions with Netgear it was called a ghost share and I waited perhaps months for a fix that actually worked.
I have had other issues with the 102 causing me to lose data and I had to perform a complete reinstall.
Seriously thinking today whether to get the old V1 up and running again.
John
The only response I have had from my support request was asking for the serial number which I provided when I originally posted it and if I was the registered user of the product.
I think this NAS does start to back up through the front usb but I am not sure at what stage it locks up.
I think through the back ports overnight it got about as far as 100gb or so but I Cannot be certain before I had to shut it down.
I too used to be very happy with Readynas and I recommended them and indeed my company resells them. At the moment I would be reluctant to supply any more units and I am advising clients not to upgrade their firmware if they have a working system at the moment but as was the case with this particular NAS the end user just went ahead and upgraded it which to be fair they should be able to do in confidence that its been properly tested.
I have always supplied and recommended Netgear products and not just NAS equipment as they are generally very good and I would like to continue doing so but this episode with the NAS and the time its taking to resolve has done nothing to boost my confidence to be fair.
If Netgear want to supply me with some kit I would be quiet happy to test them! :D
Hi
Considering 6.4.0 was released in October then it sure is taking a long time to resolve the issues.
I totally fail to understand why it is that there isn't a simple authorised route back to 6.2.5. Now I know it's supposed to be possible but before I do it I would like to know if I'm going to get myself into any issues. Let's be honest what help am I likely to get if I downgrade and brick my NAS?
However given that it seems so many people have issues it's about time Netgear came clean and gave us a route to do this so we can all get our systems working again.
Once it's running properly I can't see I'm going to ever update the firmware again and please don't anyone tell me that I should because of all the new features I would get because one feature I definitely don't want is a NAS that fails to back up!
I just wonder if rather than keep the firmware and interface simple they are trying to provide too many features most of which the average person doesn't want or need and in the process have ruined some pretty basic and necessary facilities. I don't suppose we'll ever know.
John
- StephenBMar 13, 2016Guru - Experienced User
Just wanted to add that I reformatted the SSD to ext4, and tested both USB ports again. The results are here: https://community.netgear.com/t5/ReadyNAS-Beta-Release/6-5-0-T322-RN100-series-front-port-USB-performance-is-sluggish/td-p/1061142
Morning
Interesting as you say. I suppose given that the front socket is USB 2 and the rear USB 3 then some drop off is to be expected.
Thinking about this last night, not only did I get the ghost shares issue using my front socket I have also had problems under at least one firmware issue getting any USB stick recognised. I found that the insertion of the drive would not be recognised and I would have to try again and again. Strangely under 6.2.5 no problem and as I keep saying everything worked a treat.
A question. If I attempt to go back to 6.2.5 am I likely to brick my NAS?
John
- StephenBMar 14, 2016Guru - Experienced User
It looks like one recent poster just did. Though it did work for most people.
You could alternatively reformat the disk to ext, and get the paragon ext tools on the PCs so you can read the backups. That would cost $20 and might give you full performance w/o lockups.
- YorkBoyMar 14, 2016Luminary
Thanks Stephen. The thought of bricking my NAS doesn't appeal and neither does paying out good money to enable a workaround for a problem which isn't of my making.
While it works I'll leave well alone and hope that Netgear will come up with a solution.
However i have spoken to a person in consumer law and would point out that users of 102 units which freeze or fail to work as intended now have units which are not fit for purpose becuase they no longer comply with their sold specification. This potentially opens other possibilites for owners. I don't expect you to comment on this, I'm just stating this for the record shall we say.
Thanks again.
John
Your choice, just pointing out that is an option. Even with 6.2.x, ext formatting would give the fastest USB backup speed.
Another (free) option is to fire up your NV+, and use it to back up your RN102 over a gigabit network.
- YorkBoyMar 29, 2016Luminary
Stephen
I have over the last few days carried out some tests which I have documented and I think they are if nothing else very interesting.
I have passed them (in pdf) to Netgear support but wonder if you would care to look at them?
John
- StephenBMar 29, 2016Guru - Experienced User
YorkBoy wrote:
Stephen
John
Sure, can you PM me the pdf?
- barrydMar 29, 2016Aspirant
Just to remind the support team at Netgear that I am having exactly the same problems as Yorkboy with a 102 after upgrading to 6.4.2.
the symptoms are exactly the same although I am able to either manually or using third party software backup the nas across the network. The USB drives on the nas are unusable for backup now. As with Yorkboy the admin screen and access to the nas is impossibly slow when it is attempting to backup and the unit eventually freezes.
Hi Barry
Thanks for this.
For other readers.
Basically over the last two days I have carried out tests on my 102 NAS using the front USB socket.
The results are that from all five tests (using different USB sticks before anyone jumps in and grasps at straws by suggesting it's my stick that's the problem), in each case the NAS slowed down considerably. Sometimes it recovered after the backup, sometimes it didn't and finally froze requiring the power to be removed by removing the power plug as both the admin page and the power button failed to function.
As a result of this I have also discovered that backing up across my network also takes considerably longer. My last NAS to NAS backup in November 2016 (prior to 6.4.0) took just over 5 hours, the latest took five times as long in fact 29 hours to back up 143GB. So the same factors which are increasing the time taken to backup via the rear USB sockets appear to affect the NAS to NAS backup as well.
However, no doubt someone from Netgear will tell me it's me or my methods....
- Jan 17, 2024Retired_Member
