barryd
Feb 23, 2016Aspirant
Readynas 102 not backing up and freezing after upgrade to 6.4.2
My client has a Readynas 102 2x3tb system It is backed up by 2 x WD 3TB disks which are rotated and plugged into the front of the Nas. It has always been a bit problematic in that the WD driv...
- May 20, 2016
O.K. I think this discussion has run its course.
Now that this is fixed in 6.5.0 if you have any issues on that you should open a new thread.
I'm closing this thread.
YorkBoy
May 09, 2016Luminary
As an update for those of interest.
As at 9th May I have been told that 6.5.0 will solve the backing up issues.........mind you 6.4.0 was going to solve issues as well!
I have for some time been using my old ReadyNAS V1 rather than the 102 simply because it never let me down.........speaks volumes doesn't it?
I have noticed that some issues appear to clear if the 102 is simply restarted prior to attempting a backup but which will then subsequently reappear at the next backup attempt.
I am in the construction business, mostly in building services (heating, lighting, air conditioning etc), I wonder if Netgear office staff would be happy if their AC failed today and I didn't put it right for over 6 months?
May 09, 2016Guru - Experienced User
The NTFS speeds are much faster with 6.5.0, I posted more specifics in the beta forum.
My guess is that release will be very soon.
- Jan 17, 2024Retired_Member
