barryd
Feb 23, 2016Aspirant
Readynas 102 not backing up and freezing after upgrade to 6.4.2
My client has a Readynas 102 2x3tb system It is backed up by 2 x WD 3TB disks which are rotated and plugged into the front of the Nas. It has always been a bit problematic in that the WD driv...
- May 20, 2016
O.K. I think this discussion has run its course.
Now that this is fixed in 6.5.0 if you have any issues on that you should open a new thread.
I'm closing this thread.
May 09, 2016Guru - Experienced User
The NTFS speeds are much faster with 6.5.0, I posted more specifics in the beta forum.
My guess is that release will be very soon.
YorkBoy
May 09, 2016Luminary
Thanks, yes support have indicated 'any day' now.
I will be interested to see if this solves my NAS to NAS issues as well. Particularly the problem that in order to carry out that weekly backup I had to power down and power up the 102 else it would report that the other NAS wasn't available, yet strangely using the TEST button in the set up routine for the backups the 102 would report all was well.
I would like to know how this NTFS issue ever got through the testing but whatever the reason theres been little excuse in my opinion to keep customers waiting over six months to resolve this. This is without doubt the very worst service I have had in any dealings with IT since my first involvement back in the 1980's, not that anyone really cares a jot do they?
- StephenBMay 09, 2016Guru - Experienced User
YorkBoy wrote:
...I will be interested to see if this solves my NAS to NAS issues as well. Particularly the problem that in order to carry out that weekly backup I had to power down and power up the 102 else it would report that the other NAS wasn't available,
Overall 6.5 betas have worked fairly well for me, the issues I found were all fixed.
My USB testing was quite limited, since I don't normally use it.
I do have quite a few NAS-NAS backup jobs running on the RN102 and RN202. But I haven't seen your particular issue, so I can't speak to that. My backups all use IP address, and not the NAS name.
- YorkBoyMay 09, 2016Luminary
"My backups all use IP address, and not the NAS name."......
Yes and so do mine.
What happens is that my NAS to NAS backups will either run incredibly slow and make access to the 102 almost impossible or they will fail. To prevent either of these issues I discovered that powering down and up the NAS just prior to the backup routine solved this.
Obviously I no longer run this routine as the 102 is gathering dust until we have a solution for the problems.
If this doesn't arrive I'll attempt a downgrade to 6.2.5 as one way or another I am determined to resolve this before the end of this month.
- YorkBoyMay 19, 2016Luminary
In case anyone is interested 6.5.0 has been released and I installed this yesterday.
Overnight my backup to a WD USB 3.0 drive took 1 hour 10 minutes to back up 144gb of mixed data which is almost exactly the same as it used to take under 6.2.5.
So one of the three issues appears to have been solved.
I still need to check my NAS to NAS backup which was taking anything up to 20 hours for the same amount of data and also the front socket the use of which would freeze the 102.
Not bad Netgear, problem arose in November 2015 and at the end of May 2016 we appear to have a solution to make the system perform as it did under 6.2.5 before installing the recommended and 'tested' firmware 6.4.0. I wonder if any of you Netgear guys would be happy if you reported a faulty boiler to me in November 2015 and I didn't get one of my engineers to find the fault until May 2016. I really hope that one day such an opportunity for me to return the favour occurs.......
Needless to say Netgear devices will never be purchased again.
- Jan 17, 2024Retired_Member
