dasmb
Apr 14, 2015Aspirant
ReadyNAS 102 not recognizing a second drive
Hi. I have a ReadyNAS 102 on the latest firmware, recently purchased with two WD RED 4TB NAS hard drives (the 5400s). When I first got everything installed, the 102 would only recognize one drive (...
mdgm-ntgr
Apr 14, 2015NETGEAR Employee Retired
You should be able to add a disk while the NAS is on. If it is a used disk you should have the option to wipe it so it can be added to the array.
Have you tested your disks using the WD Data LifeGuard Diagnostic tool? Are there any SMART errors on the disks?
