Sa9aX11
Jul 30, 2018Guide
ReadyNAS 102 Remote Access
Hi
Do anyone know the port no. to access ReadyNAS device remotely?
What to use my ReadyNAS has a server so anyone can access my files, similar how you would see it locally on the web page. I ...
Jul 30, 2018Guru - Experienced User
The port depends on the protocol you want to use - https and ftps being the ones I'd suggest. If you want to stream media over the internet, then Plex is your best option. In all these cases you can set the port number.
I don't recommend trying to enable smb or afp over the internet.
Overall, the most secure way to access your NAS remotely is to use a VPN of some kind. ReadyCloud is built into your NAS. OpenVPN is built into many routers (including Netgear Nighthawk and Orbi models). ZeroTier is another VPN you could use, there is a third-party app available for it on the NAS. For all these choices there are apps available for PCs (Macs and Windows) and mobile devices (Android and iOS). These are mostly free, though in the case of plex there is a one-time charge for iOS and Android.
Can you give us some more information on how you want to access the NAS remotely?
That is:
- file access for yourself and perhaps family?
- file access for others (not as trusted)?
- remote administration for the NAS?
- media streaming?
Sa9aX11
Jul 31, 2018Guide
Hi
First of all HTTPS & HTTP doesn't work remotely, tried also port 443 remotelly I get nothing. FTP seems work ok remotely, that
Plex (Premium) I tried that its only good for playing music but not for streaming movies I get always the message that my system is not powerful enough.
I am running:
WordPress - What is wordpress? Bulletin Board System? What Can I do?
Logitech Media Server - Audio Only server.
Subsonic & OwnCloud (v9.1.0) have the same problem, after you update it the app disappear and stops working, you stuck with an old version.
I want my NAS to be access outside (remotely) like a server so I or a friend can access and store files, play music & video.
- StephenBAug 01, 2018Guru - Experienced User
Ok. There are risks there, since hackers also can gain access through the same protocols. So you definitely want to use secure protocols and use strong passwords. Also, you want to make sure you keep your firmware up to date, since most firmware releases include some security updates. There have been posts here from folks who have had their ReadyNAS hijacked, so this is not a hypothetical risk.
One potential option is ZeroTier. You can install it on the NAS, and also on the your own (and family/friend) devices. You'd have the ability to add and drop those devices through ZeroTier's web interface. This functions like a VPN, but the access is limited to your NAS, not your full home network. All the services (SMB, AFP, etc) would be available remotely. The normal NAS user accounts and file access controls could be used to limit the access of any friends.
And you could also try ReadyCloud.
Sa9aX11 wrote:
... FTP seems work ok remotely...
Yes, but it's not secure. The FTP server in your NAS supports FTPS, and you can configure it to require FTPS (ftp with explicit TLS). Many FTP clients support FTPS, including WinSCP, Filezilla, and several apps for iOS and Android.
Sa9aX11 wrote:
HTTPS & HTTP doesn't work remotely, tried also port 443 remotely I get nothing.
Again, HTTP isn't secure, so you shouldn't be setting that up for remote access (other than perhaps for public wordpress stuff).
If you have remote management enabled in your router, it might not actually forward 443 (even if it's in the port forwarding list). Some ISPs also block those ports - you might want to check that with http://canyouseeme.org/
One option with https is to enable the secondary port number in the NAS settings. Ideally the secondary port is in the range reserved for dynamic/private ports (49152-65535). Then forward that in your router, and specify it in your URLs. For instance, if you chose 54321 for the secondary port, you can reach the NAS with https://ddns-name:54321/admin
I have used the RN102 for streaming movies. It's not able to do real-time transcoding, you'd need a more powerful NAS for that. If your network connection isn't fast enough for direct-play, then you could still do some off-line conversion (creating a lower quality version of the movie that can be streamed over the internet).
Another scenario is that your plex client might not support for the audio or video format - that's another case where transcoding might be needed. For instance, movies that use DTS audio. Again, off-line transcoding is the only way around this with the RN102.
These aren't just plex issues - you'll run into these issues with any streaming platform.
What is your ISP upload speed?
- Sa9aX11Aug 01, 2018Guide
I checked the ZeroTier site but I can't find the app that works on my NAS device, I looked at ZeroTier downloads I see no .deb versions, I checked out https://download.zerotier.com/debian/ and I see a few ending xxxx_armhf.deb that installs on my NAS Device but it doesn't appear on my NAS apps list, tried a few armhf on each directory it installs but nothing appears.
ReadyCloud don't like it its confusing, you need to create a link to share the files, I don't want to do that.
FTP or FTPS I want to use on my browser, don't want to use a separate program.
AICloud Web uses port 443.
AiCloud content streaming uses port 8082
As for my upload speed its 1-2Mbps its faster early in morning, my download speed 102 Mbps (Morning) & 40-60 Mbps (8 - 12.00am)
- StephenBAug 02, 2018Guru - Experienced User
https://github.com/NAStools/zerotierone/releases
Sa9aX11 wrote: FTP or FTPS I want to use on my browser, don't want to use a separate program.
Bad idea. Browsers don't support secure FTP. It's safe if you are accessing via a VPN, but not over the open internet. User names and passwords are sent as clear text with normal FTP, so hackers who can see the traffic can access your NAS using those credentials. FTPS eliminates that vulnerability.
That's enough for direct streaming of music and some SD video content, but not enough for anything else. Typical 720p movies need 3-6 Mbps; 1080p videos often need 8 Mbps or more.
Options include
- transcoding movies off-line to fit your internet bandwidth (probably keeping the higher quality versions for local viewing)
- upgrading your internet service to get a faster upload
- upgrading the NAS to a more powerful model that can do real-time transcoding
- hosting the plex server on a PC that can do real-time transcoding, keeping the content on the NAS
You can only forward an internet port to one device. If you are using 443 (and 8082) for AiCloud, then you can't use them with the ReadyNAS. If you aren't using AiCloud, then the ports it needs aren't relevant.
FWIW, port 443 is the standard port for https. Lots of stuff uses it - which isn't a problem when you are connecting outbound from your home network. But inbound you can only forward port 443 to one device. I told you how to overcome that in the previous posts.
