Sa9aX11
Jul 30, 2018Guide
ReadyNAS 102 Remote Access
Hi
Do anyone know the port no. to access ReadyNAS device remotely?
What to use my ReadyNAS has a server so anyone can access my files, similar how you would see it locally on the web page. I ...
Sa9aX11
Jul 31, 2018Guide
Hi
First of all HTTPS & HTTP doesn't work remotely, tried also port 443 remotelly I get nothing. FTP seems work ok remotely, that
Plex (Premium) I tried that its only good for playing music but not for streaming movies I get always the message that my system is not powerful enough.
I am running:
WordPress - What is wordpress? Bulletin Board System? What Can I do?
Logitech Media Server - Audio Only server.
Subsonic & OwnCloud (v9.1.0) have the same problem, after you update it the app disappear and stops working, you stuck with an old version.
I want my NAS to be access outside (remotely) like a server so I or a friend can access and store files, play music & video.
Aug 01, 2018Guru - Experienced User
Ok. There are risks there, since hackers also can gain access through the same protocols. So you definitely want to use secure protocols and use strong passwords. Also, you want to make sure you keep your firmware up to date, since most firmware releases include some security updates. There have been posts here from folks who have had their ReadyNAS hijacked, so this is not a hypothetical risk.
One potential option is ZeroTier. You can install it on the NAS, and also on the your own (and family/friend) devices. You'd have the ability to add and drop those devices through ZeroTier's web interface. This functions like a VPN, but the access is limited to your NAS, not your full home network. All the services (SMB, AFP, etc) would be available remotely. The normal NAS user accounts and file access controls could be used to limit the access of any friends.
And you could also try ReadyCloud.
Sa9aX11 wrote:
... FTP seems work ok remotely...
Yes, but it's not secure. The FTP server in your NAS supports FTPS, and you can configure it to require FTPS (ftp with explicit TLS). Many FTP clients support FTPS, including WinSCP, Filezilla, and several apps for iOS and Android.
Sa9aX11 wrote:
HTTPS & HTTP doesn't work remotely, tried also port 443 remotely I get nothing.
Again, HTTP isn't secure, so you shouldn't be setting that up for remote access (other than perhaps for public wordpress stuff).
If you have remote management enabled in your router, it might not actually forward 443 (even if it's in the port forwarding list). Some ISPs also block those ports - you might want to check that with http://canyouseeme.org/
One option with https is to enable the secondary port number in the NAS settings. Ideally the secondary port is in the range reserved for dynamic/private ports (49152-65535). Then forward that in your router, and specify it in your URLs. For instance, if you chose 54321 for the secondary port, you can reach the NAS with https://ddns-name:54321/admin
I have used the RN102 for streaming movies. It's not able to do real-time transcoding, you'd need a more powerful NAS for that. If your network connection isn't fast enough for direct-play, then you could still do some off-line conversion (creating a lower quality version of the movie that can be streamed over the internet).
Another scenario is that your plex client might not support for the audio or video format - that's another case where transcoding might be needed. For instance, movies that use DTS audio. Again, off-line transcoding is the only way around this with the RN102.
These aren't just plex issues - you'll run into these issues with any streaming platform.
What is your ISP upload speed?
