Sa9aX11
Jul 30, 2018Guide
ReadyNAS 102 Remote Access
Hi
Do anyone know the port no. to access ReadyNAS device remotely?
What to use my ReadyNAS has a server so anyone can access my files, similar how you would see it locally on the web page. I ...
Aug 02, 2018Guru - Experienced User
Sa9aX11 wrote:
I checked the ZeroTier site but I can't find the app that works on my NAS device
https://github.com/NAStools/zerotierone/releases
Sa9aX11 wrote: FTP or FTPS I want to use on my browser, don't want to use a separate program.
Bad idea. Browsers don't support secure FTP. It's safe if you are accessing via a VPN, but not over the open internet. User names and passwords are sent as clear text with normal FTP, so hackers who can see the traffic can access your NAS using those credentials. FTPS eliminates that vulnerability.
Sa9aX11 wrote:
As for my upload speed its 1-2Mbps
That's enough for direct streaming of music and some SD video content, but not enough for anything else. Typical 720p movies need 3-6 Mbps; 1080p videos often need 8 Mbps or more.
Options include
- transcoding movies off-line to fit your internet bandwidth (probably keeping the higher quality versions for local viewing)
- upgrading your internet service to get a faster upload
- upgrading the NAS to a more powerful model that can do real-time transcoding
- hosting the plex server on a PC that can do real-time transcoding, keeping the content on the NAS
Sa9aX11 wrote:
AICloud Web uses port 443.
AiCloud content streaming uses port 8082
You can only forward an internet port to one device. If you are using 443 (and 8082) for AiCloud, then you can't use them with the ReadyNAS. If you aren't using AiCloud, then the ports it needs aren't relevant.
FWIW, port 443 is the standard port for https. Lots of stuff uses it - which isn't a problem when you are connecting outbound from your home network. But inbound you can only forward port 443 to one device. I told you how to overcome that in the previous posts.
Sa9aX11
Aug 02, 2018Guide
Zerotier-One they all failed to install tried nt1_ to nt3_armel.deb.
I switch off AICloud (443) & ReadyCloud don't like to use a link for a file.
- StephenBAug 03, 2018Guru - Experienced User
What firmware are you running on the NAS?
Are you saying that you don't have remote https access to the NAS when you've forwarded port 443 in your router with AICloud off?
- Sa9aX11Aug 03, 2018Guide
ReadyNAS 102 Firmware: 6.9.3
No I switched off AiCloud off, I don't want to use it.
I suspect your installation issues are related to your first attempts to install ZeroTier. If an install fails part-way through it can interfere with future installs.
I have an RN102 that doesn't have ZeroTier on it, if I have a chance I'll install it and post back on my results.
