Sa9aX11
Jul 30, 2018Guide
ReadyNAS 102 Remote Access
Hi
Do anyone know the port no. to access ReadyNAS device remotely?
What to use my ReadyNAS has a server so anyone can access my files, similar how you would see it locally on the web page. I ...
Aug 03, 2018Guru - Experienced User
Sa9aX11 wrote:
Zerotier-One they all failed to install tried nt1_ to nt3_armel.deb.
What firmware are you running on the NAS?
Sa9aX11 wrote:
I switch off AICloud (443)
Are you saying that you don't have remote https access to the NAS when you've forwarded port 443 in your router with AICloud off?
Sa9aX11
Aug 03, 2018Guide
ReadyNAS 102 Firmware: 6.9.3
No I switched off AiCloud off, I don't want to use it.
- StephenBAug 03, 2018Guru - Experienced User
I suspect your installation issues are related to your first attempts to install ZeroTier. If an install fails part-way through it can interfere with future installs.
I have an RN102 that doesn't have ZeroTier on it, if I have a chance I'll install it and post back on my results.
- Sa9aX11Aug 04, 2018Guide
I had same problems with a few apps, eg. Owncloud and Subsonic when I update the apps they disappear or stop working, maybe a need a cleanup, like backup everything, format or wipe and re-install the apps again.
