Sa9aX11
Jul 30, 2018Guide
ReadyNAS 102 Remote Access
Hi
Do anyone know the port no. to access ReadyNAS device remotely?
What to use my ReadyNAS has a server so anyone can access my files, similar how you would see it locally on the web page. I ...
Aug 03, 2018Guru - Experienced User
Sa9aX11 wrote:
ReadyNAS 102 Firmware: 6.9.3
I suspect your installation issues are related to your first attempts to install ZeroTier. If an install fails part-way through it can interfere with future installs.
I have an RN102 that doesn't have ZeroTier on it, if I have a chance I'll install it and post back on my results.
Sa9aX11
Aug 04, 2018Guide
I had same problems with a few apps, eg. Owncloud and Subsonic when I update the apps they disappear or stop working, maybe a need a cleanup, like backup everything, format or wipe and re-install the apps again.
