milkster
Dec 29, 2013Aspirant
Readynas 102 slow read speed from NAS
I just purchased the ReadyNas 102. It has 2 x 1TB WD RED Drives in it. I am seeing very slow read performance from the unit. When I copy a file from my PC to the NAS the write performance is acce...
Dec 31, 2013Guru - Experienced User
If you are buying a switch, it is good to check the datasheet for 802.3x flow control.
It doesn't matter much if everything is gigabit - but if you have some 100 mbit devices mixed in it is sometimes necessary to get good performance. I have a media player with a fast-ethernet nic that requires flow control to work properly when I access media libraries on a gigabit device.
