johnshortland
Dec 30, 2013Aspirant
ReadyNAS 104 - 6.1.5 same issue as 6.1.4
So as per post in this thread http://www.readynas.com/forum/viewtopic.php?f=65&t=73537&start=105 Called netgear support asked to join Beta program, they emailed NDA and then the firmware t...
johnshortland
mdgm wrote: What model disks are you using and what are the SMART+ stats for the disks like?
Drives are WD RED WD30EFRX from the HCL
Smart status is perfect. I think it is the same issue with the btrfs filesystem as 6.1.4
Disk usage is at around 70% and wont copy anymore just like previous firmware.
