johnshortland
Dec 30, 2013Aspirant
ReadyNAS 104 - 6.1.5 same issue as 6.1.4
So as per post in this thread http://www.readynas.com/forum/viewtopic.php?f=65&t=73537&start=105 Called netgear support asked to join Beta program, they emailed NDA and then the firmware t...
coxo01
Dec 31, 2013Aspirant
Having the same issues, however I have managed to "minimize" these hangs.
First off I enabled login via FTP and use TRANSMIT to connect to the NAS. Then I just copy ONE file over at a time and it works. It does hang from time to time but nowhere near the hang rate if I copy over SMB or AFP.
Also I disabled the antivirus on the NAS.
I understand that this is not "ideal" but it will do for now while Netgear fixes this RN104 piece of JUNK they sold us.
thanks,
Alfonso
thanks,
Alfonso
