xfixiate
Jul 04, 2026Aspirant
READYNAS 104 - has booted into safe mode with no drives?
Hi, Can anyone please help? Booted up, seemed to be working OK (but very slow), Then froze with a "do_exit+4c8" error. Drive lights were on. Wouldn't shut down, so two hard power cycles, sam...
Jul 04, 2026Guru - Experienced User
Can you download the log zip file?
Also, if you have a windows PC, it would be useful to test the disks with vendor tools. You might need a USB-SATA adapter or dock to do this.
You'd use SeaTools for Seagate disks and KitFox for Western Digital.
FWIW, the error is a NAS crash.
It might also be worth powering down the NAS and disconnecting it from power for a while (15 minutes or so). That will clear any residual bios state. Then power up again and see if the symptoms change.
