Richard-P
Mar 29, 2021Aspirant
Readynas 104 - Very slow, almost unusable
Hi, I'm using a readynas 104 with 6.10.4 Hotfix 1 OS. It's extremely slow, almost unusable and I can't get any work done, which is a real problem. The latest log says 'System: ReadyNASOS backgroun...
Apr 07, 2021Guru - Experienced User
You could also just uninstall clamav, instead of disabling it.
rn_enthusiast
Apr 07, 2021Virtuoso
That is true. It could be un-installed with:
apt-get remove clamav*
Thing is, that I don't know how the NAS will react if the default services file tries to enable it, but the package is gone? Never thought about that.
- StephenBApr 07, 2021Guru - Experienced User
I believe uninstalling clamav will also remove the service files.
