TickT0ck
Jul 17, 2022Aspirant
ReadyNAS 104 - Volume: Volume data health changed from Degraded to Dead
Hi there, I have a ReadyNAS 104 that has reported the following in the log files: 10 Feb 2022 08:43:34 PM Disk: Disk in channel 1 (Internal) changed state from RESYNC to ONLINE. ...
Jul 17, 2022Guru - Experienced User
What are the smart stats on the disks? Disk 1 looks like it might be failing.
Also, what did you do to recover from the dead volume last January?
- TickT0ckJul 17, 2022Aspirant
Disk 1 looks like this:
The other disks have error rates of Disk 2 = 225, Disk 3 = 197, Disk 4 = 271.
I haven't posted to this forum with a problem for several years, I did however comment a couple of times on another post where someone had had exactly the same error that went unresolved. Rather than keep adding to that one I was advised to create a new post with my issue.
I had a seperate issue several years ago that was resolved - I think someone remote connected to my NAS and fixed something from (aging) memory - however I have since removed those disks and effectively started afresh a few years ago with these WD Red disks.
Cheers,
Gary.
- StephenBJul 17, 2022Guru - Experienced User
Can you download the log zip file, and the copy/paste disk_info.log in a reply?
