servando
Dec 05, 2014Aspirant
ReadyNAS 104 ERR: Could not mount boot flash #24308679
Hello, My RN104 does not start. It shows in the LCD screen "ERR: Could not mount boot flash" and the power button blinks. It does not respond to the power button and I've removed the HDDs after plugi...
servando
Hello,
I've never entered with ssh in the device and it just stopped working, I did not update it neither change the configuration before the error. I power it off (always pressing several times the power button) sometimes when I go to bed and yesterday when I tried to start it I found out that it does not work. I'm a little bit puzzled.
The code that I've shown corresponds to the commands that I've used to create the usb for boot, in my computer. I've tried to follow this link:
http://www.readynas.com/kb/faq/boot/how_can_i_perform_a_boot_recovery_using_a_usb_flash_device
However, I must be doing something wrong. I think that the command that I've used to create the image is correct so maybe I'm not starting correctly the NAS to boot by the USB.
I've not tried the factory default option, but I don't know if it is going to help as the unit does not boot and returns the same error without disks.
In addition, I've the device protected by an APC UPS, I think that electrical problems can be discarded.
Thanks
Thanks
