servando
Dec 05, 2014Aspirant
ReadyNAS 104 ERR: Could not mount boot flash #24308679
Hello, My RN104 does not start. It shows in the LCD screen "ERR: Could not mount boot flash" and the power button blinks. It does not respond to the power button and I've removed the HDDs after plugi...
thelk
Jul 08, 2015Aspirant
Hi
mdgm provided a solution for me. The NAS is buzzing again..
So some warm Major Kudos to him.
'Major Kudos!'
'Major Kudos!'
- dmacleoSep 01, 2015Guide
I have exact same issue after trying to update to 6.2.4
init stuck on
ERR: could not mount boot flash
tried removing all discs and putting unused one in and doing reinstall/resets of course, no luck.
can someone please send me the info?
suspect its something inb the tech section of boot menu but I have never looke dthere.
- StephenBSep 01, 2015Guru - Experienced User
init stuck on
If you are the original purchaser (and still have warranty left) then contact support. If the flash has failed, then you should get an RMA replacement. The hardware warranty is 3 years.
filed support ticket but if its matter of just refalshing I am willing.
