vtech92
Jun 08, 2021Aspirant
ReadyNAS 104 lost X-RAID volume after degraded disk replacement
Hi all, my RN104 (6.2.4) reported a failed disk (#3 of 4 3TB disks) with the data degraded msg. I removed the disk and connected to my Win10 PC to check. Disk Management recognized the disk. I del...
vtech92
Jun 23, 2021Aspirant
Hi, an update on my data recovery journey. After a few weeks of trying different things, I finally have recovered my data using ReclaiMe.
For your and others information, here is the sequence of events:
- Clone/copy disk #1 using hardware
- Using a 2-bay disk duplicator, attempted to clone disk 1 to a new 3TB disk. The duplicator would not read disk #1.
- Clone/copy disk 1 using SW
- Connected disk #1 to Win PC via sata
- Attempted to clone or copy disk using a number of applications. None worked.
- They all returned errors, all related to I/O issues
- I swapped sata cables and ports, nothing worked
- I'm quite concerned disk #1 is truly dead....although Win disk management shows it is healthy
- Checked to see if RAID array can be detected
- Used a few applications to check if they recognize the RAID array
- They all did but non-would complete the process. They all seem to stall at some point.
- Decided to use ReclaiMe File Recovery to detect RAID array and find files
- Connected all 4 disks to WIn 10 PC via sata
- ReclaiMe Ui is a bit old school but was actually pretty intuitive
- It began finding files and folder structures
- It stated that when files and folders are found, I can save/recover them while in process
- I decided to activate ReclaiMe File Recovery Ultimate and see if files can actually be recovered
- After multiple days of continuos detection and file recovery, I have recovered the data that matters to me...so it worked.
I think the post mortem validates that while disk #3 was resyncing, disk #1 failed big time. I'm lucky there was enough data integrity and physical life left in the failed drives for ReclaiMe to recover the ~3TB of data.
Going foward, I'll be trying a different RAID approach and of course backing up the data. Thanks for the insight and guidance.
Jun 23, 2021Guru - Experienced User
I'm glad to hear you recovered your data. Thx for following up.
