jhsg
Nov 13, 2017Aspirant
ReadyNas 104 network connectivity issues
Hi, I am using a readynas 104 on firmware 6.8.0. The NAS was working fine and every time I went into the dashboard I was getting automatic notifications about firmware updates. The oth...
Nov 13, 2017Guru - Experienced User
what model switch?
Did you try bypassing it, and connect the NAS to the router directly again?
jhsg
It’s a TP-LINK SG1005D. Works fine when I bypass the switch but as noted in my original post my other devices plugged into the switch aren’t impacted.
Thanks.
Thanks.
- StephenBNov 13, 2017Guru - Experienced User
I'm not seeing much you can do other than bypass the switch. Though it seems odd that this only affects internet connectivity, and not local access.
Something incompatible with the "green" ethernet mode?
