Calm's avatar
Calm
readynas 104 replaced drive rebuilt data still showing data degraded
Have a readynas 104 - drive in slot 1 failed - tested new drive all tests passed replaced with same make and model it detects and rebuilds volume showing raid 1 once rebuilt it still comes up wit...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Sep 14, 2016
    Well I would backup the data onto another disk if you can (don't try and overwrite the existing data).
    Then with only good new disks in the NAS do a factory default (wipes all data, settings, everything) and restore your data from backup.
ProSupport for Business
