Calm
Sep 10, 2016Aspirant
readynas 104 replaced drive rebuilt data still showing data degraded
Have a readynas 104 - drive in slot 1 failed - tested new drive all tests passed replaced with same make and model it detects and rebuilds volume showing raid 1 once rebuilt it still comes up wit...
- Sep 14, 2016
Well I would backup the data onto another disk if you can (don't try and overwrite the existing data).
Then with only good new disks in the NAS do a factory default (wipes all data, settings, everything) and restore your data from backup.
Calm
Sep 11, 2016Aspirant
Ok have upgraded to 6.5.2 no problems
However the resync says it has finished but data still degraded
The second drive in the array has ata errors on it so I have replaced this with a new disk which I have tested with seagate tools and passed long test
Now the new drive i have put in is showing green online but blackd out and there seems to be no way of forcing a resync I have pulled the drive back out waited 10 minutes and then replaced it with the same results.
I am unable to access my data at this point as I cannot get disk 2 to sync with disk 1 as I had to replace disk 1 as it failed as well how do I force a sync with the good drive in disk 1 from the bad drive.
Then I could simply replace the sick drive and resync and all would be ok
thanks
mdgm-ntgr
Sep 12, 2016NETGEAR Employee Retired
Do you have a backup?
- CalmSep 12, 2016Aspirant
Yes have backup
is there a way to tell the sync to ignore the ata errors so the bad disk would sync with the good one as with the bad disk in the data is still readable.
It says it is rebuilding to the new disk and finishes but says not redundant so obviously it isn't writing the entire drive across.
thanks
- StephenBSep 13, 2016Guru - Experienced User
The sync requires re-writing every sector on the newly inserted disk. If that fails you aren't in sync - so if some other disk fails it's content can't be reconstructed correctly. I don't think the ATA errors can be ignored, the system needs to take some action (re-issue ATA commands, etc) when they occur.
- CalmSep 13, 2016Aspirant
so it seems there is no solution for this scenario but to destroy the volume and re-setup all the shares and all the backup settings.
I wonder if I cloned the old disk to a new disk with acronis and then tried to resync which in theory should get past the ata errors which seems to be the bug bare.
