leew87
Mar 20, 2019Aspirant
READYNAS 104 System volume root's usage error
hi
this morning i have recieved an Alert of the following
"System volume root's usage is 87%. This condition should not occur under normal conditions. Contact technical support." how do...
leew87
thanks for your swift reply
i have followed the instructions is there a way i can check the s System volume root's usage has returned to normal?
the only reason i knew it has increase was a email i recieved yesterday
Mar 20, 2019Guru - Experienced User
leew87 wrote:
is there a way i can check the System volume root's usage has returned to normal?
Log in via ssh again, and use df to tell you the space usage. For example
Welcome to ReadyNASOS 6.9.5 root@NAS:~# df // -h Filesystem Size Used Avail Use% Mounted on /dev/md0 4.0G 940M 2.9G 25% / root@NAS:~#
Normally it will be about 25% used.
- leew87Mar 20, 2019Aspirant
thanks for your reply it seems i am still at 41% after this fix
Welcome to ReadyNASOS 6.9.5 root@ILLIT-STORAGE:~# df // -h Filesystem Size Used Avail Use% Mounted on /dev/md0 3.7G 1.5G 2.1G 41% / root@ILLIT-STORAGE:~#
has i missed anything?
- StephenBMar 20, 2019Guru - Experienced User
41% should be safe. But it would be useful to understand why it's that high.
Do you have other apps installed? If so, which ones?
Also, do you connect USB drives to the NAS? If a drive doesn't mount properly, then sometimes files end up copied to the system root (either through drag/drop, or a backup job).
Hi StephenB
in answer to your questions
1) i have no apps installed
2) i have removed the backup jobs recently (in the last 48 hours) as i am in the processing of adding more storage to the remote readynas that it was backing up so the old backups failed for the last week or so.
3) i have turnt Anti Virus off on the system this morning and restarted to try and resolve the issue before posting here and getting instructions to remove temp files.
4) no USB connected to the NAS in any way
i have re-run df to check useage and here are the results
Last login: Wed Mar 20 11:11:37 2019 from illit-main
/dev/md0 3.7G 1.1G 2.4G 32% /also re-run the comand below to shows there are no tmp files listed as per the fix but i am still at 31% unsure why this is still here than what you expect to see.
Last login: Wed Mar 20 11:43:08 2019 from illit-main
root@ILLIT-STORAGE:~# cd /var/lib/clamav
root@ILLIT-STORAGE:/var/lib/clamav# ls -lsh
total 456M
4.0K -rw-r--r-- 1 root root 48 Mar 6 10:24 antivir.ini
992K -rw-r--r-- 1 root root 990K Jan 2 17:03 bytecode.cld
162M -rw-r--r-- 1 root root 162M Mar 6 10:23 daily.cld
294M -rw-r--r-- 1 root root 294M Jun 8 2017 main.cld
4.0K -rw------- 1 root root 1.5K Mar 20 11:12 mirrors.dat
