Martok867
Apr 22, 2015Aspirant
ReadyNAS 104 will not shutdown
ReadsyNAS 104 4 x 2TB Unit will not shutdown or reboot even if I leave it for 12 hours. I have to pull the plug and restart it this way - not a good option. Any ideas? No apps running, nothing ...
atai1
Apr 24, 2015Aspirant
I have more or less the same problem.
I have a ReadyNAS RN104 with 2 disks (2TB and 3TB).
It seems that after the software updating to 6.2.3 something doesn't works.
After some minitues of inactivity the system look like freeze; I can't ping the NAS anymore and the power button don't work for shutdown the system and the only way is to pull the plug and restart it.
Only one app running (transmission)
