Martok867
Apr 22, 2015Aspirant
ReadyNAS 104 will not shutdown
ReadsyNAS 104 4 x 2TB Unit will not shutdown or reboot even if I leave it for 12 hours. I have to pull the plug and restart it this way - not a good option. Any ideas? No apps running, nothing ...
mdgm-ntgr
Apr 25, 2015NETGEAR Employee Retired
Systems exhibiting the lockup problem tend to also have had that problem on 6.2.2.
Looking at your logs I think it is worth checking to see if there is a problem with a disk.
