Martok867
Apr 22, 2015Aspirant
ReadyNAS 104 will not shutdown
ReadsyNAS 104 4 x 2TB Unit will not shutdown or reboot even if I leave it for 12 hours. I have to pull the plug and restart it this way - not a good option. Any ideas? No apps running, nothing ...
Apr 25, 2015Guru - Experienced User
Do you have disk spindown enabled?
atai1 wrote: After 7 hours the Disks test is still running and now is fixed to 90% since long time.
What I can do now?
If so, disable it, and wait somewhat longer. Perhaps also look at the SMART stats and see if there are any errors so far.
