Martok867
Apr 22, 2015Aspirant
ReadyNAS 104 will not shutdown
ReadsyNAS 104 4 x 2TB Unit will not shutdown or reboot even if I leave it for 12 hours. I have to pull the plug and restart it this way - not a good option. Any ideas? No apps running, nothing ...
atai1
Apr 26, 2015Aspirant
Thanks for the answer.
Just an update about the system situation:
I have done a test, it seems that the system works properly if I use the NAS, so I have run a ping/t of the NAS IP address and now the RN104 is working properly.
Regarding your suggestion I have first download the log and attached you can see the SMART history log file
For the second point could you please let me know how to do it?
The disk spindown has been always disable
There is only one app running and is transmission
model serial realloc_sect realloc_evnt spin_retry_cnt ioedc cmd_timeouts pending_sect uncorrectable_err ata_errors timestamp time
WDC WD10EFRX-68JCSN0 WD-WCC1U4968420 0 0 0 -1 -1 0 0 0 1421601375 2015-01-18 17:16:15
ST3000DM001-1CH166 Z1F0YLF7 0 0 0 0 0 0 0 0 1426097097 2015-03-11 18:04:57
