Martok867
Apr 22, 2015Aspirant
ReadyNAS 104 will not shutdown
ReadsyNAS 104 4 x 2TB Unit will not shutdown or reboot even if I leave it for 12 hours. I have to pull the plug and restart it this way - not a good option. Any ideas? No apps running, nothing ...
mdgm-ntgr
Apr 26, 2015NETGEAR Employee Retired
You can install 6.2.2 via the web admin interface.
Go to System > Settings > Update, click the Install Firmware button and browse to where you have downloaded the 6.2.2 firmware to, select it and follow the prompts.
