Martok867
Apr 22, 2015Aspirant
ReadyNAS 104 will not shutdown
ReadsyNAS 104 4 x 2TB Unit will not shutdown or reboot even if I leave it for 12 hours. I have to pull the plug and restart it this way - not a good option. Any ideas? No apps running, nothing ...
atai1
May 04, 2015Aspirant
It locked again also with 6.2.2 so I decided to disable the virus checker and from that moment it seems that works.
What do you suggest? Leave like this and test some days or move to 6.2.4?
