ItsMatt
Mar 31, 2016Aspirant
ReadyNas 1100 5MB/s transfer speed
Hi!
I've recentley inherited a readynas 1100.
I reset everything to factory defaults and installed 2 x 2TB WD Green drives. The disks are in RAID 1.
I went through the wizard and pretty much left everything on default and enablled large packets? (I have forgotten the option exactly)
I seem to only get 5MB/s sometimes 6. And I cannot for the life of me figure out why.
I have tested the drives they are both performaing well and achieved about 100 - 110 MB/S R/W on an Ubunutu system.
I was wondering if there was anything that could be causing this. Please let me know if theres any more information that may help.
Also I have ruled out the network as I can connect to a PC connected to the same Router and achieve close to 100MB/S transfer speeds.
That would be the MTU size? Try resetting back to 1500 and see if there is any change.
Also, what file sharing protocol are you using?
What firmware is it running?
- ItsMattAspirant
Hi, Thanks for the response!
I shall try changing the MTU - as for the firmware I'm not able to access it at the moment but I had it updated to latest one avalible. I can let you know which that is later today!
thanks again,
Matt.
- Cliff_MIGuide
It looks like you are connected at 100 mb/s. Please check the network tab to make sure that you are connected at Gb/s
I am assuming that you are on OS6 vs OS4
Good Luck
