chrispiner
Jan 03, 2017Aspirant
ReadyNAS 1500 Blank Front View
Hello. We have a ReadyNAS 1500 that was working well until today. HDD 4 showed a blinking light so the unit was powered down. Upon powering the unit back up, FrontView allows you to log in (http:...
- Feb 06, 2017
You've got a bad disk (probably disk 4). I've sent you a PM with details that should help you confirm which disk it is.
JennC
Jan 03, 2017NETGEAR Employee Retired
Hello chrispiner,
I have some questions to ask, I have summarized them below:
- Does RAIDar still detect the NAS?
- If so, what does it say?
- Can you still access the shares through Windows explorer?
- What is the current firmware version?
- How many disks are inserted?
- Do you have backup of the data?
It is possible that there is more than 1 disk causing the problem to access the NAS.
Welcome to the community!
- chrispinerJan 05, 2017Aspirant
Thanks for your reply.
- RAIDar does still detect the NAS and labels it as: Volume C: RAID Level X2. Not Redundant. A disk failure will render this volume dead.
- We can still access the shares through Windows Explorer
- The current firmware version is 4.2.19
- There are 4 disks in the NAS, all of size 2TB.
- There is no backup of this data :smileymad:
Thanks!
Chris
Or rather, there isn't yet. There will be very shortly!
- StephenBJan 05, 2017Guru - Experienced User
chrispiner wrote:
- RAIDar does still detect the NAS and labels it as: Volume C: RAID Level X2. Not Redundant. A disk failure will render this volume dead.Does it show a problem with a specific disk? Also did you try hovering the mouse over the volume and disk icons?
Current firmware is 4.2.30, you might want to upgrade to that after the problem is resolved.
When was the last time you successfully accessed the admin interface?
Initially, it looked as though it had no issues with any as it showed 4 HDDs with green ticks on them all. However, on hovering, it shows 6 ATA errors on disk 3 and no data at all for disk 4, showing just 'Channel 4: 0'
We last accessed the admin panel on Tuesday. After a reboot, the admin panel was no longer accessible.
Thanks for your reply,
Chris
