snoopy888
Aug 05, 2022Aspirant
ReadyNAS 2000 Issues¬
Hi I was given this NAS and im struggling to set it up. RAIDar is showing corrupt root. I have tried to perform a factory reset and OS install using the reset button to no avail. I cannot get to ...
- Aug 05, 2022
snoopy888 wrote:
Disk is WD Red NAS drive WD60EFRX
Ok. The WD60EFAX is SMR, so not a good choice. But the WD60EFRX should be fine.
I do recommend removing the partitions in the windows disk manager. Maybe also test it with WD's dashboard utility while it is connected.
If the partitions are all removed, then the NAS should automatically do a factory install when the system powers up. No need to use the boot menu.
snoopy888
By the way it keeps showing Corrupt root! I cant work out how to get rid of this stupid message!
