snoopy888
Aug 05, 2022Aspirant
ReadyNAS 2000 Issues¬
Hi I was given this NAS and im struggling to set it up. RAIDar is showing corrupt root. I have tried to perform a factory reset and OS install using the reset button to no avail. I cannot get to ...
- Aug 05, 2022
snoopy888 wrote:
Disk is WD Red NAS drive WD60EFRX
Ok. The WD60EFAX is SMR, so not a good choice. But the WD60EFRX should be fine.
I do recommend removing the partitions in the windows disk manager. Maybe also test it with WD's dashboard utility while it is connected.
If the partitions are all removed, then the NAS should automatically do a factory install when the system powers up. No need to use the boot menu.
snoopy888
By the way it keeps showing Corrupt root! I cant work out how to get rid of this stupid message!
Aug 05, 2022Guru - Experienced User
Does your NAS say
- ReadyNAS Duo on the front panel? or
- ReadyNAS Duo v2 on the front panel?
Please ignore other labels for this check. Operation of the boot menu is a bit different, depending on what you have.
snoopy888 wrote:
I removed the HDD too and formatted them in windows
FWIW, a bad idea. The NAS doesn't use the file systems used in Windows. What disk model are you using?
