Nantuc
Jun 09, 2017Star
ReadyNAS 204 - Seagate 8TB Archive Drives Keep Failing
I have had nothing but problems using my ReadyNAS 204 and 4x Seagate 8TB Archive Drives. I would have no problem with a drive failure taking two weeks to re-initialize as long as it was truely a dri...
- Jun 21, 2017
Thanks for the feedback everyone. The original issue was the failing drives. My answer was the firmware update to v6.7.4. I was just about to spend a ton of money only because I could not keep the drives from failing over and over. I use the NAS simply for storing videos and almost, if never, need to delete any files, just add to them. The Raid stripe is all the redundancy that I require and has proven reliable despite over 10 drive failures since last Xmas.
As long as the drives remain as stable as they have for the last week, even after moving new videos to it each day, I am perfectly happy with the performance of the 8TB Seagate archive drives in my ReadyNAS 204. Hopefully they won't mess anything up that fixed this problem in subsequent firmware updates (crossed fingers).
I consider this thread closed. If the drives become unstable in the future, or I need to upgrade, I will definately get NAS ready drives.
Again,
Thanks,
mdgm-ntgr
Jun 15, 2017NETGEAR Employee Retired
OS6 x86 to OS6 ARM whilst technically possible is not recommended.
OS6 ARM to OS6 x86 is a good way to go.
Where possible you should make sure that your regular backup is up to date before migrating disks across.
Jun 16, 2017Guru - Experienced User
I accidentally did it, and it did work. The knowledge base article does not have any restrictions: https://kb.netgear.com/22895/ReadyNAS-OS-6-Migrating-a-volume If that is incorrect, it should be changed.
I do suggest uninstalling any apps before you migrate to different platform type, and reinstalling them when you are done.
