Nantuc
Jun 09, 2017Star
ReadyNAS 204 - Seagate 8TB Archive Drives Keep Failing
I have had nothing but problems using my ReadyNAS 204 and 4x Seagate 8TB Archive Drives. I would have no problem with a drive failure taking two weeks to re-initialize as long as it was truely a dri...
- Jun 21, 2017
Thanks for the feedback everyone. The original issue was the failing drives. My answer was the firmware update to v6.7.4. I was just about to spend a ton of money only because I could not keep the drives from failing over and over. I use the NAS simply for storing videos and almost, if never, need to delete any files, just add to them. The Raid stripe is all the redundancy that I require and has proven reliable despite over 10 drive failures since last Xmas.
As long as the drives remain as stable as they have for the last week, even after moving new videos to it each day, I am perfectly happy with the performance of the 8TB Seagate archive drives in my ReadyNAS 204. Hopefully they won't mess anything up that fixed this problem in subsequent firmware updates (crossed fingers).
I consider this thread closed. If the drives become unstable in the future, or I need to upgrade, I will definately get NAS ready drives.
Again,
Thanks,
Nantuc
Jun 19, 2017Star
Well, I was about to knuckle under and accept defeat, but ... Ever since I upgraded to v6.7.4 of the OS and after the new rebuild that only took 2 days instead of two weeks, I am happy to say that the NAS has been stable for the longest period since I bought it last Xmas. I have transferred over 1TB of data to it this weekend, which in the past, had nearly instantly triggered a drive failure. I don't want to jinx myself, but if it remains stable, then the problem was the firmware all along, wouldn't you say? I am not saying the firmware was buggy, but maybe improvements were made to accomidate slower reacting drives like my archive drives. Either way, I am going to keep my fingers crossed, and hope for the best,
Jun 19, 2017Guru - Experienced User
Possibly, since they are taking linux kernel updates fairly regularly.
Still, they aren't designed for RAID, so over time I suggest you switch to NAS-purposed models.
