sakmanga
Jun 16, 2017Aspirant
ReadyNAS 2120 OS6 - AD group "Domain users" automatically has full control granted on subfolders
Hi all, I have a ReadyNas 2120 v2 OS 6.7.4 working in an active directory.
I created shared folders following the instruction in:
https://kb.netgear.com/7066/ReadyNAS-OS-6-Setting-Active-Directory-folder-permissions
The problem I discovered is that when I create a subfolder the AD group “Domain users” is automatically added to the new folder with full control granted.
Have anyone discovered how to solve this problem?
I really appreciate your help,
- JennCNETGEAR Employee Retired
Hello sakmanga,
You need to set permission on the subfolders too. The permission on the shares and subfolders are handled by the AD when the NAS is joined to the AD.
Welcome to the community!
- sakmangaAspirant
Hi JennC, thank you very much for your replay.
Probably I didn't explained correctly the case.
Let’s try with an example:
Imagine this tree structure:
MainFolder
|_ SubFolder
I create the root folder (MainFolder) and configured:
From NetGear Admin page:
Network Access:
SMB only, Allow Anonymous access = False
File Access (as default):
Folder Owner=Administrator
Folder group = Domain Admins
Everyone = RO
Folder Owner, Folder Group, Domain Admins = R/W
From Windows Client (as described on doc https://kb.netgear.com/7066/ReadyNAS-OS-6-Setting-Active-Directory-folder-permissions):
Removed Read premission to "Everyone" group.
At this point "Domain Users" have no access at all to the folder.
Now lets create the subfolder SubFolder.
I expected the inheritance was respected but the goup "Domain Users" is automatically addeed to SubFolder with full control on it.
So if I give, for example, read only access to MainFolder to a user or a group of users they automatically will have full access to SubFolder.
I think this is a bug on this version of OS because I didn't have this problem in previous versions.
Have a nice day.
- HopchenProdigy
Hi,
When you create a new folder, that folder will inherit permissions from its parent folder. This is pretty standard, so if your share has full control (R/W) for Domain Users then your subfolder well as well. You want it be this way generally else you would have to set new perms on all new folders/files manually :)
If you don't want a given subfolder to inherit permissions, then just disable inheritance from the Windows side.
Cheers
- sakmangaAspirant
Hi Hopchen, thanks for your replay.
Unfotunatelly the inheritance is not respected as I explained in my post to JennC.
Have a nice day.
