PaulHZ
Apr 24, 2018Aspirant
ReadyNAS 2120 volume inactive
Our ReadyNAS 2120 (firmware 6.9.3) has some SMB shares on it, the permissions were not working correctly so I rebooted the device as I had done many times before, it was approaching full but as the p...
- Apr 24, 2018You may wish to contact support then.
mdgm-ntgr
Apr 24, 2018NETGEAR Employee Retired
kernel.log is showing filesystem errors:
Apr 24 11:31:06 kernel: BTRFS error (device md127): bad tree block start 6482798579101298558 17641198419968 Apr 24 11:33:07 kernel: BTRFS error (device md127): bad tree block start 6482798579101298558 17641198419968 Apr 24 11:33:07 kernel: BTRFS error (device md127): bad tree block start 6482798579101298558 17641198419968 Apr 24 11:34:47 kernel: Btrfs loaded, crc32c=crc32c-generic Apr 24 11:34:48 kernel: BTRFS: device label 0e350b3e:data devid 1 transid 680874 /dev/md127 Apr 24 11:34:49 kernel: BTRFS info (device md127): setting nodatasum Apr 24 11:34:49 kernel: BTRFS critical (device md127): unable to find logical 49012342784 len 4096 Apr 24 11:34:49 kernel: BTRFS critical (device md127): unable to find logical 49012342784 len 4096 Apr 24 11:34:49 kernel: BTRFS critical (device md127): unable to find logical 49012342784 len 4096 Apr 24 11:34:49 kernel: BTRFS critical (device md127): unable to find logical 49012342784 len 4096 Apr 24 11:34:49 kernel: BTRFS critical (device md127): unable to find logical 49012342784 len 4096 Apr 24 11:34:49 kernel: BTRFS critical (device md127): unable to find logical 49012342784 len 4096 Apr 24 11:34:49 kernel: BTRFS error (device md127): failed to read chunk root Apr 24 11:34:49 kernel: BTRFS error (device md127): open_ctree failed
Have you tried booting to volume read-only mode?
It's not advisable to let your data volume get that full.
I'm guessing from what you've said that your backup is not up to date
PaulHZ
How do I boot to Read Only mode?
It was on my list to clean up the shares but it is a archive of older backups so getting the nod to remove them takes time.
It is phsycially accessible so I can get to it and connect/run whatever I need to in order to get this resolved.
