gesent's avatar
gesent
Follower
Dec 24, 2018
readyNAS 2120 Volume: Volume data is Degraded.
readyNAS 2120 Volume: Volume data is Degraded. But their is no indication of the field drive. Drive's are in a raid 5 one volume. How i can get more info on what caused the error?
  • StephenB's avatar
    Dec 24, 2018
    Download the log zip file from the web ui.
    mdstat.log will tell  you what disks are in each Raid group; disk_info.log will give you the SMART statistics for each disk.
ProSupport for Business
