KenTravis
Feb 01, 2016Aspirant
ReadyNAS 3100 all disk lights flashing red
I recieved a ReadyNAS NASRNRP4000 last weekend. When I powered it up and the disk failor lights where flashing red in unison. Other servers can access the data, but I can not access it via IP address...
kohdee
Feb 01, 2016Administrator
You can hook up a console cable to the back and watch the startup. Copy/paste the output if you can.
Or you can try an OS reinstall to reset network adapters/admin pw and reinstall the OS, and see if you can see in RAIDar after that.
Maybe check your initrd.log file and see if your flash image is corrupt.
- KenTravisFeb 01, 2016Aspirant
I am able to watch it boot up. Do you know any trick to copy the text as it does, so I can post it? Thanks -ken
- kohdeeFeb 01, 2016Administrator
I use PuTTY or KiTTY for my console connections. Both have the same option to copy the output. Make sure your window is large enough to capture all of the startup.
I believe you have an ability to attach a file to the post -- save the output as a text file.
Both also do logging to a file.- KenTravisFeb 01, 2016Aspirant
Oh, I didn't know about the serial port. Can I fix this issue with terminal access?
Phoenix TrustedCore(tm) Server
Copyright 1985-2007 Phoenix Technologies Ltd.
All Rights ReservedReadyNAS-3100 Rev 1.3
CPU = 1 Processor Detected, Cores per Processor = 2
Pentium(R) Dual-Core CPU E5300 @ 2.60GHz
DRAM Type : DDR2-800, FSB at 800MHz
2048M System RAM Passed
Press <DEL> for SETUP|
| CPU Type : Pentium(R) Dual-Core CPU E5300 @ 2.60GHz |
| CPU Speed : 2.60 GHz |
| Physical CPUs : 1 of 1 Enabled Logical CPUs : 2 of 2 Enabled |
| System ROM : E46C - FFFF |
| Installed memory : 2048 MB BIOS Date : 04/07/10 |
| Available to OS : 2046 MB |
| Used by devices : 2 MB COM Ports : 03F8 02F8 |
| LPT Ports : 0378 |
| Display Type : EGA \ VGA |
| Hard Disk 0 : 1000GB SATA1 PS/2 Mouse : Installed |
| Hard Disk 1 : 1000GB SATA2 |
| Hard Disk 2 : 1000GB SATA3 Diskette A : 1.44/1.25 MB 3/" |
| Hard Disk 3 : 1000GB SATA4 |
| Hard Disk 4 : None |
| Hard Disk 5 : None |
<?xml version="1.0"?>
<machine-info>
<name>IMAGESERV</name>
<guid>94a4d153-63d6-e7a0-890b-30469a800cfa</guid>
<processor-architecture>AMD64</processor-architecture>
<os-version>6.0</os-version>
<os-build-number>6002</os-build-number>
<os-product>Windows Server 2008</os-product>
<os-service-pack>2.0</os-service-pack>
</machine-info>
Computer is booting, SAC started and initialized.Use the "ch -?" command for information about using channels.
Use the "?" command for general help.
SAC>
