Gianlucam
Jan 13, 2019Tutor
ReadyNAS 312: after power outage drives seem empty
Hi. I've had a power outage and when power came back my ReadyNAS 312 was stuck on the "Connecting to the ReadyNAS Admin Page...".
I removed the 2 drives and restarted it to go into "safe mode", and...
Gianlucam
Jan 13, 2019Tutor
I just managed to change the default admin password ("password") to my actual admin password and I got this error screen.
I want to follow the steps to recover critical data, but how do I force an OS reinstall?
Thanks,
-Gianluca.
Sandshark
Jan 14, 2019Sensei
OS re-install is selected from the boot menu.
I don't know if I'd try that first, even though Netgear seems to recommend it. It is possible that only one of your drives is corrupt. Try booting in read-only mode with each drive individually (read-only mode is also selected from the boot menu). If it comes up and all looks well with just one of them, except it complains your volume is degraded (which means "not redundant," not "corrupt") , and all content looks good, then boot normally with just that drive. At that point, it is best to back up everything, just in case more goes wrong. Once you have done that, insert the other drive with power on. You may need to manually re-format that drive, then it will sync with the first one.
- GianlucamJan 20, 2019Tutor
Thank you Sandshark both drives were corrupted (tried one at the time in read-only).
So I inserted only one and did an OS-reinstall and I got my data back! :)
I saved all my data to an external drive, and reformatted the drive in the NAS. and put the data back on it. All is good so far.
Now I want to add the second drive (that was there before power failure) as a *full redundancy drive* (not a parity drive), and I'm a little confused.
The first drive that's there (mounted and with data) says it's of type JBOD, but under the drive bay image it say it's in RAID-1, so which is it? JBOD or RAID-1? I thought JBOD and RAID-1 were 2 different RAID levels, so I can't understand how they can apply to the same drive.So I inserted the second dirve (that was there before power failure) and removed any volume from it, but now I can't see how I can add this second drive as full redundancy drive.
There's the option to switch to X-RAID with this second drive (the X-RAID button on the right side of the web interfafe), but the popup warning message says that any new free drives will be used as expansion, which is not what I want. I don't want storage expansion, I want full-redundancy.
And on the left-side of the page it only gives me "add parity" or "add group" as options, but not add-as-full-redundancy.
How can I add this second drive as a full redundancy to the first drive?Thanks,
-Gianluca.
@Sandshark just to be clear, I'd like to add this second drive in a fully reduntant RAID-1 mode.
I figured out that the "add parity" button doesn't actually add a disk which contains only parity bits, but it creates a redundant RAID-1 disk.
What a poor choice of verbiage for that button, and poor indications of what that button does.
I had to download the software manual and find the "Volume Operations Table" to figure out what that button does.
Very unclear user interface... :(I'm good now, the second drive is re-syncing.
Thanks,
-Gianluca.
